I have floorplans to be attached to my drawngs. As many others I want my flooplan references greyed out.
I generally work in dgns. I attach the floorplan, Set the overrides of all levels to grey and switch the reference >Presentation "Level Overides" on. That works well with dgn-references. Yet often I just attach dwg-floorplans. I was under the impression that with the attachment of an dwg I should be able to also use the overrides. And so it appears. But after reopening the overide settings are lost.(To be more precise:The Presentation Level Overide is still on but the attachments overides colors are all lost)
I am sure that I used this ever so often for DWG-attachments as well. But now it does not work any more(?) If my memory serves correctly we had the issue on an off with previous versions(?) .I am increasingly doubting my recollection when I am seeing issues long time overcome popping up again.
Gerd Eisenacher said:I was under the impression that with the attachment of an dwg I should be able to also use the overrides. And so it appears. But after reopening the overide settings are lost.(To be more precise:The Presentation Level Overide is still on but the attachments overides colors are all lost)
Perhaps someone could test this with V8i to see if the behaviour has changed in CONNECT?
Jon Summers said:Perhaps someone could test this with V8i to see if the behaviour has changed in CONNECT?
Yes, it works fine and retains the override settings after closing and reopening.
Have you tried saving a DWG to DGN? Which version of V8 are you using here?
Need help for the selected function? Click into the "Toolsettings" dialog and press F1 For Screenshots try Win+Shift+S on your Keyboard - Using "ScreenRecorder" for Videos Brauchst Du Hilfe zur gewählen Funktion? Klicke in das "Funktionseinstellungsfenster" und drücke F1
I avoid the conversion process it inherits the autocad colour table into the dgn file and I need the dgn to be a dgn colour table especially when clients have custom colour tables... The way I do things for acad conversion to dgn is to create new dgn with correct seed file and colour table etc. then ref attach the autocad dwg then create a selection to cover the dwg and use copy elements to copy all the elements I want etc into the msnt dgn this works much more reliably for me and doesnt bring bad elements or phantoms etc from acad. The merge command should work too but sometimes I get rubbish I cant delete or see but its in the level this comes mostly from acad hatch patterns and from shared cells...
Its advisable to compress or purge your DWGs first and the same for microstation you should compress from time to time.. saves a lot of heart ache later..
Lorys
Currently Using V8iss10 (8.11.09.919)
and dabbling in CE update 16 (10.16.00.80)
and now
Pwise Administrator ( yeah I passed the training course!)
Lorys said:ref attach the autocad dwg then create a selection to cover the dwg and use copy elements
Can you expand on this?
The copying (for me) produces more rubbish colorwise.
The problem is often that the acad colors - still - define linewith which are only plot correct when a particular .ctb is provided to plot with.
