I have a dwg file that has loads of hyperlinks. They are nice to have but a real pain when I create a pdf.
How can I remove these links?
Could be more specific? Do have elements that have hyperlinks attached to them or do you mean you have hyperlink text?
The key here is how were the hyperlinks placed in the DWG?
If the links were placed originally in a DGN converted to DWG you might be able to use an old keyin "delete webtag" to remove hyperlink.
A sample file might help to get a better idea of what you are dealing with.
Regie
The links were created in a dwg file
the key-in Links delete all seems to work to get rid of them
Kirk
I Wish Cadland was Reality
Ok, thank you for sharing that information.
