Docking the Key-In dialog in Connect edition
How do I dock the Key-In dialog in the Connect edition? I can bring it up by pressing "Enter" but I want dock it like I've always been able to do since I've been using Ustn. In a related question, how do I start a line with the starting point at 0,0,0? Using Connect that is. I know how to do it in every version prior.
Thank you, Eric. version 10.15.00.74
  • Simply drag it up top, just above your View.
    To start at 0,0,0, xy=0,0,0
  • Thanks Bob. I can easily do this in previous versions of Ustn (v8i and older). I can't figure out how to do it in Connect. How do I drag it? If I click on it nothing is present that allows me to move it. In previous versions I got the things that popped up that allowed me to dock it. If I am ever able to get it docked then I can use the "xy=0,0,0" key-in.
    Eric
  • Connect r17 10.17.2.61 self-employed-Unpaid Beta tester for Bentley
  • Bob, Thanks for posting the video. What you're showing looks like version "v8i". I know how to do it in "v8i". I'm trying to do the same in the "Connect" edition.
  • In CONNECT, open the Key-in window by selecting this icon.
    That will open the Key-in window that you can dock.
    Rod Wing
    Senior Systems Analyst
    Answer Verified By: EricG
