Since updating to CONNECT Edition 10.16 we've been having the following issue where, when trying to move the dimension text along a dimension line using the "Modify element" tool, accudraw won't properly rotate to the view when using the left/right view rotations, needing the user to press "V" to rotate the accudraw to view first.
The issue does not surface when using the back/front or top/bottom views, during which the view does rotate automatically properly.
See attached video.
Is this a bug that others have run into, or am I missing some (obscure) setting that causes this behaviour? In our previous version 10.14 accudraw would always rotate properly when using modify element, regardless of the view rotation.
Regards,Remy
Can you share a screenshot of your AccuDraw setting Operation tab?
Here you go:
You appear to have the same settings enabled as I do in V8i, and I also see the same behaviour with the AccuDraw orientation, although my AccuDraw appears the left side of my dimensions.
However, if you disable Context Sensitivity, it works as I believe you are looking for.
Answer Verified By: Remy Moerland
