Hi
This is an very nice plot/print help to get the right scale to your plot/print and see how the print area is overlapping your design.
https://communities.bentley.com/products/microstation/w/askinga/1222/create-plot-shapes-with-this-macro
Can someone change this to Connect edition ?
//Tom
Suggestion: use sheets and you don’t need the macro
Hi Barry
Can you please make an video where you place an sheet at right coordinate system and right plot size/area and print pdf file, Then take the pdf file as an raster reference attachment, if it places itself on the same coordinates as you printed it I believe you.
As an alternative i would also suggest looking at named boundaries:
https://communities.bentley.com/products/microstation/w/microstation__wiki/25068/named-boundaries
https://communities.bentley.com/products/microstation/w/microstation__wiki/25090/automating-sheet-creation-using-drawing-boundaries-and-named-boundaries
Along with drawing boundaries this may help it setting up sheet files for printing.
Hi David
Yes you right, there is a lot of options. But if you would want to print in size X and in scale Y and also in right coordinate system (PDF) under an minute your suggestion is not making the time or geolocatiion.
DavidI don´t know if you can do it or not but if you can please share how you did it.
