Hi everyone,
Could you please help to explain for my understanding about this issue:
When I change color and weight in level manager of "model" (or "drawing"), why both level and line weight not updating automatically in "sheet"?
Causing that I have to update level manager manually for "sheet". Because if I use "update level", it could also change to original color of all reference.
I am using MicroStation CONNECT Edition.
Thank you so much.
There are a number of options you can perform to ensure the level attributes are synchronized from your reference to master but here are a number of considerations.
Reference file levels do not update within master design file
Answer Verified By: Tuan
Thank you, Andrew Bell,
Your advice related to update level from reference to master.
But my issue that is in one dgn file, when I update color and line weight in master model, the color and line weight in sheet is not change (same overrides mode), therefore I must update it manually in sheet accordingly, it means twice update for any element I edited.
Tuan
OpenRoads Designer CE - 2021 Release 2
(Version 10.10.21.04)
Do you use level libraries? If so how are they defined in your workspace? Is there a variable that loads them into level manager (sort of like a reference file) or do you import your levels into the active file?
We need to know how things are defined and your workflow.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Dear mwlong,
Thank you, I have fixed and understood my issue.
Simply, Because MicroStation doesn't update level automatically from model (or drawing) to sheet, I need to update it manually on sheet as picture below:
The reason I asked the questions that I did is because I am trying to figure out how your levels are set in your file. There are configuration variables that can be set that may automatically update your levels.
