I am no longer able to edit Tag elements created in U16 in either CE or v8i versions.
Tag has character type but any input results in empty tag. Same happens accessing Tags using VBA it only supports integer type. What is happening?
Try the attached DGN:
ST-tags.dgn
Not sure what you did, but I simply remade it (See additional Design Model) and it works fine now.ST-tags BL.dgn
Are you thinking this is bug from CONNECT i.e. making them unusable?
Sorry wrong file. This is the file I created in CE. How did you remade it?
Workflow is as follows:
ST-tagsCE.dgn
I simply dropped the cell to its original elements and attached the tag to the line and inserted the cell from the additional model.
I'm not sure changing the type is a good idea as it probably has unexpected consequences.
Would using a Text Element be an option or are you reporting the Tags?
Hi Oto,
I believe this issue is also being analyzed in SR 7001407383. I'll be sure to communicate with you here as well.Just like Barry, I was also able to remake the tag elements in MSCE 10.16.03.11 and the issue no longer persists.
Can you post the versions of MSCE and MS v8i that you are currently working with?V/R,Jayson P.
U16.3 and SS4
