I just installed Open Roads. I have been using Microstation Connect Edition Update 16. I had a font called 101 Leroy that was linked to several of my line styles. It has now disappeared and has been replaced with 101 Feature_Control_Symbols. This has happened in the past when I upgraded to a newer version and I was able to correct it, but the path is no longer the same. Can anyone tell me how to retrieve the original font please?
Hi Daryl,
If you need further help on this, feel free to file a Support Case with us here:https://bentleysystems.service-now.com/csp
If you file it, let me know the Case # (CSxxx.....) and I can work with you on this.
-JP
