Can someone tell me what's going on with the attached DGN file?
There's a single line-string element. If I pop the Properties dialog it tells me that it's on Level (none)...
If I look at the Level Display dialog I can see level Structure. I can turn the display of that line-string off and on using that dialog. No DGNLib is attached.
StructureLevel.dgn
It may be relevant that the DGN file was converted from a DXF file.
Seem like CONNECT is doing CONNECT things....
It looks like a bug in the Properties dialog as the V8i Element Information dialog shows the Level without any issues:
Does the Level manager have a 1 in the Elements column against the 'Structure' Level?
I opened the file in CONNECT and it looks fine.
Update-16
Timothy Hickman
Main: 877 627 3772|
