We have a issue where Microstation Connect / Topodot crashes on a Azure virtual server
Connect version 10.16.2.34, clean installationTopodot Pointcloud Engine Version 2021.1.1.1Topodot Extraction Tools Version 2021.1.0.0Azure server: Standard NV32as v4 (32 vcpus, 112 GiB memory - Windows (Windows 10 Enterprise for Virtual Desktops))
The Microstation application keeps crashing, and it seems like it's when users are trying to load points in Topodot.
Anyone with same issue?
The event viewer log says eg.
Application: MicroStation.exeFramework Version: v4.0.30319Description: The process was terminated due to an unhandled exception.Exception Info: Bentley.Licensing.Client.API.V1.LicenseAPIException at Bentley.Licensing.Client.API.V1.ServiceClientAPI.SubscribeToEventNotifications() at Bentley.Licensing.Client.API.V1.ServiceClientAPI.EventRefresh(System.Object) at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.TimerQueueTimer.CallCallback() at System.Threading.TimerQueueTimer.Fire() at System.Threading.TimerQueue.FireNextTimers()
Faulting application name: MicroStation.exe, version: 10.16.2.34, time stamp: 0x61a8d30bFaulting module name: KERNELBASE.dll, version: 10.0.19041.804, time stamp: 0x0e9c5eaeException code: 0xe0434352Fault offset: 0x000000000002d759Faulting process id: 0x5c98Faulting application start time: 0x01d85aca5faf2bafFaulting application path: C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\MicroStation.exeFaulting module path: C:\windows\System32\KERNELBASE.dllReport Id: e7cdd77d-e3f2-4c2f-9be5-08d609087cf7Faulting package full name: Faulting package-relative application ID:
The program Bentley.Connect.Client.exe version 11.0.4.15 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel. Process ID: b360 Start Time: 01d85ab4e86be12e Termination Time: 4294967295 Application Path: C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\Bentley.Connect.Client.exe Report Id: 7ffcfb4c-4eb7-4864-bb42-7dc505db270d Faulting package full name: Faulting package-relative application ID: Hang type: Top level window is idle
Hi Brian,
The exception seems to point to Bentley License and connection Client. Have you posted your question in that forum https://communities.bentley.com/communities/other_communities/licensing_cloud_and_web_services/ ?
Make sure you provide connection client logs https://communities.bentley.com/communities/other_communities/licensing_cloud_and_web_services/w/wiki/52104/how-to-collect-and-submit-logs and also perform this test to see results communities.bentley.com/.../--run-license-health-check-manually-outside-of-connection-client
and review https://communities.bentley.com/communities/other_communities/licensing_cloud_and_web_services/w/wiki/36380/faq---connection-client and https://communities.bentley.com/communities/other_communities/licensing_cloud_and_web_services/w/wiki/58164/microsoft-azure-virtual-environments
