How to draw the Xline like AutoCAD in MicroStation
HI everyone,
I'm using MicroStation CONNECT Edition,
and I want to draw an line as same as Xline of AutoCAD in MicroStation,
Could you please guide how to do it?
My purpose that is drawing an long line by two points in order to find the intersecting point with other line.
Thank you so much.
Parents Reply Children
  • No problem Parker.
    Here is a slightly advanced alternative that demonstrates a different use of the AccuDraw to get the same intersection point, but without Intersection Snap:
    1. Start Place Line
    2. Make sure the AccuDraw is highlighted
    3. Tentative Snap to ANYWHERE on the line (I chose the mid-point)
    4. Press RE
    5. Move the cursor over the line until it rotates parallel with the line
    6. Left-Click to accept AccuDraw rotation
    7. Press N to make Nearest snap active for 1 Data-point
    8. Move the cursor towards the intersection point
    9. Press Enter to lock the Axis
    10. Tentative Snap to ANYWHERE on the second line
    11. Left-click to accept intersection point.
