We have recently started using Section Callouts and now want to update our environment to have our most used settings applied by default.To this end I've tried updating our GUI.dgnlib, DrawingSeed.dgnlib, Menu.dgnlib and our seed files. However none seem to store the settings for the following
Place Section Callout > Drawing Seed:Create Drawing dialogue > Name and checkboxes for Create Drawing Model and Create Sheet ModelAnd when attaching a Callout as reference for the default used "Reference Presentation" settings:Any pointers to where the default for this are stored and how they can be edited would be much appreciated.
Remy
Hi Remy,
Thanks for your post.If you are running into trouble with setting up your Section Callouts, I would first recommend following the below directions if you have not done so already:To Create a Custom Drawing Seed for a Section Callouthttps://docs.bentley.com/LiveContent/web/MicroStation%20Help-v22/en/GUID-69C7925B-33E5-1647-CC51-AD9DC445F277.html
Sources of settings for saved views and references can be found here:Source of Settings for Saved Views and Referenceshttps://docs.bentley.com/LiveContent/web/MicroStation%20Help-v22/en/GUID-18E3211B-B5FD-288B-6DC6-DFD2A6E42B2D.html
If further analysis is needed, I would recommend creating a Service Request online via https://apps.bentley.com/srmanager/ProductSupport so you can work through this with an analyst.
HTH,Jayson P.
Answer Verified By: Remy Moerland
