In the New MicroStation Connect, every time I print to a PDF, I keep getting a default "-Model-000.pdf" added to the file name.
For example: The drawing name is: "4-111_Arch_A-101_Floor_Plan.DGN".
I want to print it as a pdf as: "4-111_Arch_A-101_Floor_Plan.pdf", NOT as "4-111_Arch_A-101_Floor_Plan-model-000.pdf". How do I get rid of the "-model-000" or "-layout-000" from the PDF file name?
Thanks!
William Harrison said:In the New MicroStation Connect
Bentley Systems introduced MicroStation CONNECT in 2015, so it's not so new any longer. As of May 2022, we're using Update 16.
William Harrison said:I want to print
There's a Printing Forum that might be a better place to ask your question. You can move your post using the More=>Move button.
Bentley Connect 16 is new to me. Connect 16 hides things and makes it harder to do the work. I've spent at least 2 hours of my own time looking for this answer. It is a Connect 16 specific issue, which is why I posted it here.
Edit your pltcfg to remove that part from the filename
Hi William,
Thanks for the post.One way to achieve this would be to change the Default Print File Name contained within the .pltcfg file.Try following these steps to resolve your issue:
1. In Windows File Explorer, navigate to C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\pltcfg2. Copy the file pdf.pltcfg & paste it in your project directory. This is an arbitrary location. I chose the Desktop for my case.3. Load MicroStation and open your .dgn file you want to print4. File>Print>Print to open the Print Dialog5. Within the Print Dialog, File>Select Printer Driver Configuration and choose the .pltcfg file you pasted previously. Open this .pltcfg file so it is loaded.6. Back in the Print Dialog, navigate to File>Edit Printer Driver Configuration. A new window will appear. In this new window, go to Base Properties tab>Default Print File Name section>File Name setting7. By default this setting will be defined as $(MS_PLTFILES)$(basename(_DGNFILE))-$(MS_PLTMODELNAME)<autoInc?prefix=-?digits=3?base=0>Remove part of this definition so it only reads $(basename(_DGNFILE)) as shown8. File>Save in this pop-up window and then close9. Now back in the Print Dialog, File>Reload Printer Driver Configuration10. Now print your .dgn file and the output .pdf should be the title of the design file itself. For example, if your design file was titled test.dgn, the resulting pdf would be test.pdf automatically
Here is some further reading on editing printer driver configuration files:
Configuring Print File Name - wikihttps://communities.bentley.com/products/microstation/w/microstation__wiki/13492/configuring-print-file-namePrinter Driver Configuration Files - online documentationhttps://docs.bentley.com/LiveContent/web/ProStructures%20Help-v6/en/GUID-E017B7B3-F032-B63B-FA4A-73CCC5E2044C.html
HTH,Jayson P.
