Bit of a strange one: I have some 3D polylines created by cutting vertical sections through a topography mesh. When I open them in Microstation (or any other modelling or drafting package) they appear in top-down view, and look like a single straight line. If I rotate them or select a preset front / side view the detail in the section appears. However as the sections are orientated in a number of different angle (when viewed in plan), none of the preset view buttons (front, back, left, right) allow for the section to be viewed from the side, exactly side-on. My question is: does anyone know of a way I can repeatably orientate my view so that I am looking at these different sections from exactly side-on?
Hi David,It sounds like you could benefit from using Saved Views in MicroStation CONNECT.You can orient your 3D model to the desired state, then click Create Saved View (Drawing Workflow>View tab>Saved Views Ribbon Group>Create Saved View)
Here are some tool settings I would recommend for the Create Saved View tool. This would create a general saved view from the View Window.
Left click in the view window that displays your desired view. A saved view will be created and can be recalled anytime by selecting Apply Saved View:
Once the Saved View is created, it can be applied to any view later on, so if you are working on another face, you can easily revert the view back to the Saved View to get back to the desired face.Here is the online help documentation on Saved Views:https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v20/en/GUID-3B409467-D5A9-8E36-B0F4-05975A209419.html
Also, this video on our Bentley MicroStation Youtube channel is worth a watch:https://www.youtube.com/watch?v=EOuyBBXf5R0&ab_channel=BentleyMicroStation
HTH,Jayson P.
That's great once you know how to create a view orientation to save, but I believe OP is asking how to get the view orientation to begin with.
I believe that he is describing a view cube rotated around the Z axis so that the X axis is aligned parallel to the "Top" view of the element (and Y kind of just rotates with it).
I believe it can be accomplished with an ACS. You may want to look at those capabilities. I don't use them often enough...but I think that would allow you do define your coordinates to align with your element so that you can get a view (Front or Side) that shows exactly what you want to see. After you get that, you can Save both the ACS and the View to be recalled later.
MaryB
Yes, good point MaryB, thanks!I agree that using the ACS tools in combination with the Saved Views would be a good approach.An AccuDraw shortcut I frequently use is R+A which will allow you to define an ACS by points.
Thank you both for your posts! Yes Mary is correct, I can orbit manually to the rough position I want, but I actually need to be exactly side-on / perpendicular to the section. The complicating factor is that each section's orientation is a little different, so I've got to figure out a workflow to do this more than once. Sounds like ACS might be the tool I need =)
Sounds like you need to save several ACSs, one for each section. (Try "by Points")
One has to "Define ACS" first an then use the first icon to "Create a new ACS" - maybe the thinking is that you rather often define ACSs on the fly and Save/Create them only sometimes
Then make sure that the ACS Plane Lock is on.
When you then use View Rotateion:Top View the view orientation is to the XY of the current ACS (good for slopes as well)
Switch on the "ACS Triad" to see the current ACS Orientation
And remember to "Save Settings" ...
To activate any of the "Created" ACS you just have to doubleclick or select it via
Now to view your vertical section [activate AccuDraw with "O"] press "F" (Front) and then "RV" to get the view rotated along the current ACS X/Z-Plane (or you use the Rotate View)
