When I copy and paste an image in micronation, the level is always 0.
Is it possible to change the default level of the image ?
Are you working with DGN files, DWG files, or DGN files created from DWG files?I ask because "0" isn't a standard MicroStation level, but is found and used in DWG files. This sounds like an AutoCAD/DWG function, because I have seen plain MicroStation DGN files paste the image onto the active level.
MaryB
It happens to me too, but I always change it manually later after placement...I think its an OLE thing..
Lorys
