Hi..I changed the ref by using browse option. But the ref data's not showing in the main dgn. I tried to change the nesting option and z value but it's not working.
This might be a silly question but is the sheet file name the same as the file name you are attaching?
I see in your ref dialog that you have the Hilite Mode set to Boundaries, yet I do not see any boundary showing. This indicates that you are zoomed in to far to see the extents of the reference file boundary. Try to Fit View. I also see the reference file is scaled XXX:1500. Is that the correct scale factor. Maybe it should be 1:1?
Also, have you checked if the reference file is clipped? If so, delete the clip and then Fit View.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Yeah already I tried all the details that you mentioned above but nothing is help to get the reference data. But I detached used ref and reattached the file that time the data is visible. But Ref is too big So, the work also too much if I reattach, I find the exact place and clip the correct shape and find the levels used etc.,.. that's why I need a suggestions and solutions
Raja Raghu said: that's why I need a suggestions and solutions
Yes, we get that. However, we need to ask many questions and make many suggestions because we do not have your files, we do not know your workflow & we do not know what you have done up to this point.
Perhaps you can post your files so we can try to replicate your issue.
Yeah you're right.
