I have a point in a file that I have fields in a text node linked to that give the X and Y coordinates (see image below). The issue is that when the point moves the field values don't update automatically, they only update when I reassign the field to the point. This makes the idea of using fields for this kind of purpose useless.
In V8i SS10 it worked properly and would update the fields automatically when the point is moved. Better yet was that if you copied the note and the point together to another location the new fields would automatically update to reflect the coordinates of the new point.
What did Bentley break in Connect in order to lose this functionality?
Kevin
Well, it appears that I stumbled on another known Bug:
It is just a shame that here it is 9 months later and something like this is still not fixed, how disappointing.
File a Service Ticket...?There are a lot of things that haven't been fixed for longer then nine months
MaryB
A while back I built a holding cell in V8i that worked... I followed the instructions under Mark Penns blog for v8i but its a cell and the note arrow part is fixed length is there a civ tools mdl for CE available?
Lorys
