Which "config variable" in which level is updated automatically
Hi all,
I think my question is not new, but I have not found the solutions yet.
I referenced an object from drawing to sheet. Then I had adjusted the color in level manager for this object in drawing, but I didn't see the level changed in sheet automatically.
Therefore, in sheet, I must update level manually.
Is there any config variable can help me to update it automatically?
I attached my file for your information: 4382.Drawing.dgn
Parker
OpenRoads Designer CONNECT Edition - 2020 Release 3 - Version 10.14.04.04
  • The CFG variable you are looking for is MS_LEVEL_AUTO_SYNC_ATTRIBUTE_LIST
    "This variable controls the list of level-attributes that will automatically synchronize when a file is opened. The attributes can be one or more of the following as a comma separated list : OverrideSymbology, OverrideColor, OverrideStyle, OverrideWeight, OverrideMaterial, ByLevelSymbology, ByLevelColor, ByLevelStyle, ByLevelWeight, ByLevelMaterial, GlobalDisplay, GlobalFreeze, DisplayPriority, Transparency, Lock, Plot Each of the above attributes can take a "Reference" or "Library" prefix. Without the prefix, the said attribute will be synchronized for both reference & library levels."
    So you would set this something like
    MS_LEVEL_AUTO_SYNC_ATTRIBUTE_LIST > ByLevelSymbology
    Do be aware that this will apply to every drawing you open in this workspace (or with your user account).
    If your workflow is to actually adjust levels on a "sheet" basis, or even a "collector file" basis (there are other ways to accomplish that, but people do what people do) this would undo any changes you wanted to make.
    If you don't make changes and don't plan to make changes, then this should give you what you want.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • Hi MaryB,
    Thank you for your help. But it means I need to close and re-open file in order to update automatically? Is it right?
    Tuan
    OpenRoads Designer CE - 2021 Release 2
    (Version 10.10.21.04)
  • After you fix the variable, I suggest you restart MicroStation completely. After that, it should work automatically forever after.
    MaryB
  • Hi MaryB,
    I tried to change MS_LEVEL_AUTO_SYNC_ATTRIBUTE_LIST to value 1 as picture below, but nothing changes automatically.
    I also tried to restart software, but nothing changes automatically.
    Tuan
  • The value shouldn't be 1.
    It should be the word(s) ByLevelSymbology
    MaryB
