We use labels to identify rooms, doors, ...
We place them without leaders as you can see in the screenshot here under.
Apparently when we move a label the 'association' is broken....
This is not really a problem as we can make this invisible under Preferences (Highlight Broken Associations).
But what is a BIG problem: these labels apparently do NOT translate to dwg.
Any help?
Luc Dierick
Belgium
For further info:
When we try to place labels with relative association off (screenshot here under) it is not possible to get the info of the items in the label.
I thought this was different in older versions?
Just one of the issues with labels. As long as all this is not solved I will use tags.
Really no one at Bentley caring about such issues?
Our subcontractors miss essential information because of such bugs.
How is this possible after more then seven years connect version....
Apparently this issue is still not solved?
Is anyone at Bentley conscious of this?
It makes it impossible to use labels in a production environment....
Luc Dierick said:But what is a BIG problem: these labels apparently do NOT translate to dwg.
Can you provide a sample case. Labels should show as text elements when saved to DWG.
