I have drawing files converted from Autocad, now I can't zoom it up close it has a minimum view. I can't see the entity up close to edit. Anyone to help me here? Thanks in advance.
What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help→About MicroStation in the backstage.
VERSION
See this blog that shows you how to obtain MicroStation's version number.
Armando Elumba said:I have drawing files converted from Autocad
How were those files converted? Using MicroStation, using AutoCad or using another third-party application?
Can you supply an example of a DGN file that won't allow you to zoom to an element? You can attach a file here by using the Insert button while editing your post.
I opened in Microstation and save as to DGN.
401-409 SBLR-S2-PSL-SHT-002 to 010 s.dgn
Armando Elumba said:I opened in Microstation
