MicroStation Connect version 10.16.03.11
We have a project where a client has given us a new dgnws template file that has a number of custom properties on it. We'd like to upgrade the existing dgnws to match this new template. Is it possible to either copy the sheet definitions we've already created from the old dgnws file to a new one made from the new template?
Or, copy the properties in the new dgnws over to the existing dgnws?
I tried attaching the old dgnws to a new dgnws as a reference but the sheets didn't show up.
Kevin van Haaren
What happens if you set the dgnws template as the template used to create new projects with the "_USTN_WORKSETDGNWSTEMPLATE" variable?
that's only used to create a new dgnws. We have a project with an existing dgnws, we want to create a new dgnws from their new template, then copy the sheets already in the old dgnws into the new dgnws.
I understand that the variable is used for the creation of a new dgnws file but if that delivered dgnws is set as the template via the config var, will it use that dgnws and all the existing properties for a new project dgnws? We don't experiment much with the dgnws in regards to sheet sets and properties at this time so I was curious if that works.
wow, I misunderstood and this is a very good idea. I'll give it a try.
