Hi everyone,
I have met the inconvenience with "view attribute" when I click to open it.
It will be maximized with big view as picture below:
Please help to guide me how to restore down it as normal.
Thank you so much.
----------------------------Parker
MicroStation CONNECT Edition - Version 10.16.02.34
What you've possibly done is resize the main View Attributes dialog when it was displayed as a separate dialog, rather than the pulldown. When this was closed these settings for the dialog size where saved to the User Preferences for when the pulldown option is selected. You could try resizing the separate dialog, which should in turn change the pulldown, or just reset the UPF.
How To Reset User Preferences and Delete MicroStation's Temporary Files
Answer Verified By: Tuan
Thank you so much, Andrew Bell
I got it.
Tuan
OpenRoads Designer CE - 2021 Release 2
(Version 10.10.21.04)
