Hi everyone,
When I press "shift + right click", the tool pop-up that is displayed as picture below:
Can I change the default setting of presentation by other setting of presentation, for example: "illustration: ignore lighting"?
Parker
MicroStation CONNECT Edition - Version 10.16.02.34
Hi Parker,
Please review this thread https://communities.bentley.com/products/microstation/f/microstation-forum/226357/customize-view-control-pop-up-shift-right-click
I believe you need to create your own ribbon group
Answer Verified By: Tuan
Hi Maria Garcia
Thank you so much, your instruction is useful for me.
Based on the thread as mentioned, I understand that the default setting of tool pop-up cannot be changed in normal way for almost user.
However, I can change the setting of display style which is shown in tool pop-up in order to match the display style as I want.
Tuan
OpenRoads Designer CE - 2021 Release 2
(Version 10.10.21.04)
