Hi Bentley
When is this list going to be updated for MicroStation CONNECT Edition Update 17?
//Tom
Hello Tom,
We are in the process of updating it. Our systems take some time to update.
Daniel Eng
Answer Verified By: Tom
Is the Help file up to date, or is that still being updated as well?
MaryB
The docs on docs.bentley.com are in the process of being updated. Please be patient as some of the items that are updated do not get updated right away due to the synchronization of our systems.
Thank you for your hard work, and keeping us posted on the process.I wish they could synchronize your systems to make your job easier :-)
Hi
I have to ask, is the Defect XXXX number I get information of the same as in the resolved defect number list?
Is defect Report XX different from defect XX?
See example below
Change mesh normal from selected elements don´t work in latest update as it did in previous versionsDefect Report 889687"It appears to have a High priority with our development team so should be fixed for an upcoming release."
When I have attached IFC files as reference the view display doesn't work as normalFollowing defect has been reported for this issue.Defect 1068572:[Regression][From SS4] reference Presentation Display Style does not get applied to IFC file.
