Really good to see the new Activate Parametric Component functionalily.
Will this functionality be extended to Graphic / Shared Cells at some point?
Hi Dominic,
I am glad you to hear your feedback, but we currently do not plan to extend this new functionality to Graphic and Shared cells.You can create and idea and if it gets enough traction we can evaluate its feasibility.
Marco
Oh... it's already in the Ideas portal multiple times (and there were more in the past that were consolidated).
MS-I-257 Cell EditorMSR-I-950 Easier Cell editing (dgn / dwg capable)Edit Cells in Place (Merged into MS-I-257)
I think that we anticipated that Editing Cells in Place would work on non parametric Cells. which are still the bulk of Cells in most dgns.
Is there a way to add some minimal parametrics to non parametric Cells to 'fool' Mstn into allowing Cells to be activated for editing in place?
I note that this feature is currently a Tech Preview item. It would be great to add Graphic and Shared Cells for commercial release... Update 18?
If I recall, Placement Points were also for Parametric Cells only, initially.
Hi Dominic, we will investigate support for graphic and shared cells, but these could have more limitations due to their different nature.
Many thanks, Marco!
Similarly, it would be good to extend the Auto-update welcome mat to to graphic and shared cells as well.
