Hi all,
Does anyone know if there is any way to have the new "Ability to propagate Item Type information while performing drop operation on elements" function to also work with the Drop Linestyle tool?
We regularly use 3d linestyles to quickly create things like road barriers and fencing with posts, linemarking with real dimensions, etc. and need to retain Item Types that we apply to the parent when we drop them to Mesh elements to retain information like Corridor information from OpenRoads, etc. (they have to be Mesh elements for BIM delivery).
If not, something planned?
Mark
OpenRoads Designer 2021 R2 (10.10) | Microstation CE Update 17 | ProjectWise CE 3.4
Hi Mark,
we will investigate this for one of the next releases.
Thanks Marco, perhaps integrating it into the standard Drop element dialog with a "Linestyle" option may work well. Having it as a seperate tool confuses some new users.
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Item type propagation is not supported for Line Style tool in U17.
As mentioned by Marco, will try to address in one of next release.
Sanjivani
Answer Verified By: Mark Shamoun
Thanks Sanjivani,
I've also added an Idea for some valuable enhancements of this new functionality: View idea
