I am understanding MicroStation selection behavior for Graphic Group (GG), as there are some legacy models contains such attributes. When reading What is actually a "Graphic Group"? - MicroStation Forum - MicroStation - Bentley Communities I think the behavior is GG should be selected and highlighted as a single element, however when I create a GG (the GG lock is ON) it still select and highlight each component separately. Any idea of the selection behavior?
GG.dgn
Did you "Save Settings" before closing the file?
Oh... Yes, after clicking "save settings" the settings are saved. Reopen the model the setting is back. Also I noticed when create a new document these settings are on as well, so I assume the saved settings are global for MicroStation?
