In CE17 there seems to be another layer of messy configuration options bar in already confusing config jungle. How can I get rid of them? Our Microstaton users no need to access any example configs as we use our company workspace only. Therefore I would like to turn obsolete items off so that only our own config options would be visible. What's the point making the GUI more complicated? Who needs this?
Hi Yrjo
You can right click on the unwanted links and select HIDE
Hi Ian,
Seems that I can't hide examples config.
Same problem here. So annoying!!!
We have deployed without example configurations so this option is pointless. And users have to manually select custom config each time on start which is just another thing we have to explain.
Does nobody at Bentley test this stuff in real world situations?
After I created another Configuration, there will be a file configuration.xml under folder C:\Users\<UserName>\AppData\Local\Bentley\MicroStation\10.0.0\prefs. Open this xml file and change the default configuration's tag <IsEditable>false</IsEditable> to <IsEditable>true</IsEditable>, then you can hide the default configuration. Below is my StartScreen with two configurations hidden.
