In CE17 there seems to be another layer of messy configuration options bar in already confusing config jungle. How can I get rid of them? Our Microstaton users no need to access any example configs as we use our company workspace only. Therefore I would like to turn obsolete items off so that only our own config options would be visible. What's the point making the GUI more complicated? Who needs this?
It seems this configuration.xml is new to U17, and no mention in help that I can find. It would be greatly appreciated if there's a wiki/TN for its usage. The file doesn't seem to be optional. I tried to mess around with it and ended up with no workspace/workset visible.
Thank you!
I managed to get rid of the example configurations by following your orders. This shoud definately be the default setting for the configuration selector bar! Now we need to do the same trick for another 18 workstations.....
so if you have 200 users, you will need to touch all their configuration.xml files and make this change ?
Don't you think their should be an easier way to control this from an admin perspective ?
Timothy Hickman
Main: 877 627 3772|
If the 200 users configurations are silimiar, just copy this configuration.xml to their prefs folder.
I get that and of course I can do this, but I will need to touch 200 users prefs folders (just seems very inefficient) .
It would be nice if it could be controlled by a configuration (IE: capability setting perhaps).
