Is there a way to make the priority overrule the update sequence of the references?
For example if you have:
The sequence of the references will put the elements of A on top of those in B, regardless of their priority. I would like to see them mixed together, as if there is no sequence overruling them.
Try turning on the "Ignore Update Sequence" option. This is a user setting so I would assume the next user would need the same setting turned on or the file would revert to update sequence.
Answer Verified By: StefanC
Thanks. It's not logical since every user has to have the same setting, otherwise we get different results. Also it would make sense to have it as a setting within one file, since I would use one or the other depending on the situation.
Windows 10 pro
OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
true. Would be useful if it was a file setting or a workspace variable that could be applied at specific levels. I found this. Maybe it will be of some use.communities.bentley.com/.../how-to-order-reference-attachments
