Hi All,
I cannot synchronize Google Earth with MicroStation CE. When I try to synch, I get an information box that says that this feature is not supported by versions higher than 7.1.8.3036.
I uninstalled a newer version of Earth and installed 7.1.8.3036 but I still get the information box. It's not a critical issues as the file I have exported doesn't appear to have any issues with location, etc.
This issue was reported in Bug # 802391, Google Earth Synchronization tool displaying error message of incorrect version, for MicroStation CONNECT Edition Update 16.2. It has been reported as fixed in Update 17 so we would suggest you upgrade to the latest release.
Resolved issues in MicroStation CONNECT Edition Update 17 (10.17.00.209)
Hi David
Did you manage to resolve this issue?
Hi Andrew, i just checked whether this issue has been fixed but i still get the same error message when i am trying to use sync to Google Earth, capture Google Earth picture or follow Google Earth view.I am using MicroStation CE 10.17.00.209 and Google Earth Pro 7.1.8.3036.
Hello Florian,
1.Uninstall Google Earth
2.Open Registry Editor
3.HKEY_CURRENT_USER/SOFTWARE/Google/ and here you should have a folder with the name Google Earth or Google Earth Pro or Google Earth Plus. Generally delete everything what is related to Google Earth.
Look at the screen below from my machine. I deleted both.
The existed folders depend on how many and what version you have installed on the computer.
4.Download the installation file for Google Earth v7.1.8.3036 here
5.Install the Google Earth
6.Restart computer
7.Open Google Earth and close
8.Open test dgn with simple shape and georeferenced and use the tool Export Google Earth File
9.Observe if Google Earth opens
Hallo Marta,thanks a lot that helped.
