Treat reference attachment as element (Connect U17)
Has anyone else had this happen in Connect Update 17.
Attach a model as a reference by dragging a model from model dialog box to a docked reference dialog box (method doesn't matter, i.e. coincident, etc.). Next try to click on the treat attachment as element column in the reference dialog box:
When I try this I get the following in my message center:
When I double click on the same reference file, the attachment properties pops up and it allows me to change the setting here
When I click ok the setting is now changed in the reference dialog box
So why does it now only work this way in Update 17?
