Using CONNECT U16 (10.16.00.80) with Object Enabler Civil 3D 2022.1 (13.4.1339.0) and still seeing boxes where civil objects should be:
I read about Real DWG needing to be the same version, but I believe that RealDWG 2022 is included in the U16 and not a separate install.Not sure what version of C3D was used to create these objects.Update - also tested with U17 same problem.Any suggestions?
Tom F .
Hi Tom,
Update 17 supports RealDWG 2023, so Custom Objects and Object enablers must match the RealDWG version.
Please review online documentation: RealDWG and Object Enablers https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v19/en/GUID-54181437-CB42-4B87-713C-5D8D0A0917CB.html
Please download AutoCAD Civil 3D 2023 OE from their website or contact Autodesk to get them and let us know if you still have issues.
Maria Garcia
Thanks Maria,
I've searched all over Autodesk's website and can not find object enablers for Civil 3D 2023.
Tom F.
I have sent you a link. Let me know if with them installed you still have display issues, if so, I will need to get your file to reproduce it on my side
Answer Verified By: Tom Felcone
Maria,
That fixed the problem.
Thank you,
Tom F
Hi Maria ,please can you send me the link for the object enabler for Civil 3d 2023 as i have updated my Connect to edition 17 and now need to get the enabler . I have also gone to AutoDesk web site and cannot find it
Thank you
Mike
