Using CONNECT U16 (10.16.00.80) with Object Enabler Civil 3D 2022.1 (13.4.1339.0) and still seeing boxes where civil objects should be:
I read about Real DWG needing to be the same version, but I believe that RealDWG 2022 is included in the U16 and not a separate install.Not sure what version of C3D was used to create these objects.Update - also tested with U17 same problem.Any suggestions?
Tom F .
Hi Maria,
I have the same problem, I can't correctly open dwg file made in Civil 3D. So I need "object enabler for Civil 3d 2023".
I have found only this one (https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/open-light-2023-object-enabler-64-bit.html?v=2023), but it can't be installed.
Could you send me the link for "object enabler for Civil 3d 2023" , or could you write it here for others who are in the similar troubles :)
Thank you so much
milan
Hi all,
This is should be available to download in your Autodesk Desktop App.
Mark
Thanks, Mark
