When I boot up MicroStation the past week I keep getting this message
A couple things:
-I work from home half the week and half in the office. It works in the office perfectly but when I work at home it does this.
-Seems to go down at random times. I can open up the first file I open of the day but after that I cant open anything.
-Already reinstalled MicroStation (Update 14) and connect client. Nothing seems to solve it so far. Attached the logs to hopefully help. Thank you
8562.Error.txt
Connection client is version 11.00.05.234. I do not have ProjectWise as well. Is it possible this has something to do with remoting into a VPN? That's the only difference between working from home and the office and when I'm there it works fine
