Converting dgn to dwg
Hi Community.
I'm to Microstation,
We have a bunch of files stored in ProjectWise and we need to find an efficient way to convert dgn files to dwg. Can someone please point me in the right direction?
Parents Reply
  • Thanks for providing the error message that was displayed. This issue has previously been identified as Bug # 812993 which I will provide details of, and attach, via your Service Request. I believe we do not currently have a workaround to remedy this situation but it does work fine within a MicroStation CONNECT Edition session. You might also like follow the following discussion.
    log4net:ERROR XmlHierarchyConfigurator: Cannot find Property [createpath] to set object on [log4net.Appender.RollingFileAppender]
    msbatch batchconvert from command line does not work in Connect Edition
    **Edit**
    Thanks for the discussion during our remote session. Looking through the above Forum post it was noted that a workaround was provided by another user were they found that the removal of double quotes ("") from the folder / filename for the BCNV file was a way to get this operational. The only issue is that both the folder / filename cannot contain spaces.
    Andrew Bell
    Technical Support
    Bentley Systems
