I am using Microstation Connect Edition Update 15
Is there a way I can increment existing text by a certain value? I know of the copy/increment text tool but I do not want to copy, only to update the existing text by a value of 7.
SB Owens said:Is there a way to make it work with text that is suffixed with numbers?
I've updated the macro to work with strings-with-numbers, such as your example EM-3614NS-ISS-24.
EM-3614NS-ISS-24
Download the macro here.
Answer Verified By: SB Owens
Jon,
That is amazing.
Thank you so much
SB Owens said:Thank you so much
Glad you approve!
By the way, the macro is sensitive to selection sets and fences. You can increment multiple numeric text elements in one go.
