Hellocan you give me informations about rounding up/down dimensions in MicroStation CONNECT Edition?e.g 584mm to 585mm or 582mm to 580mmThanks in advanceD
you obviously didn't do a good search of the forum 5mins in and I found this awesome blog with an mdl for CE and al the old keyins for v8i as well as pictures..
communities.bentley.com/.../rounding-dimensions
Lorys
Answer Verified By: Podda Daniele
I’ve already seen that, isn’t useful, the MDL doesn’t works in the latest Connect editions
tx
d
Microstation Connect 17 doesn’t upload the MDL then no actions are possible.
Podda Daniele said:Microstation Connect 17 doesn’t upload the MDL
Are you sure? Yongan.Fu wrote: This MDL application will unload itself.
Hi Joe
putting DLL and MDL app in the right folder Microstation (17) can see the MDL but doesn’t charge it, then no key commands are possible.
I’ve tried may times..
MSCE-U17 seems changed a lot. Old ma+dll need to regenerated by recompilation. But I am still waiting U17 SDK released.
Podda Daniele said:I’ve already seen that, isn’t useful, the MDL doesn’t works in the latest Connect editions
Sorry .. I don't have 17 but it worked in my earlier CE so assumed it would be ok... were any of the keyins useful.. you may have to just create a vba . or maybe a custom dim style might do it... not sure as in the past I just used the old keyins for v8i...
