10.17.00.209 easy question-
How can access the Area Tools dialog in the "Task Navigation" workflow?
Never mind, I figured it out.
Use Customize Ribbon (I already had a few), on the "Choose components from" button select "Ribbon Containers>Groups". If you have not any customizations, right click on "Task Navigation", select "Add New Tab", name it, add a group, name it, then add some commands or the Area Tools as desired.
Answer Verified By: Karan Sharma
Hi Bob,I'm glad to hear you were able to resolve your issue.If interested in learning more on this topic, I would recommend checking out this 4-part blog series on Ribbon Customization in MicroStation CONNECT:https://communities.bentley.com/products/microstation/w/microstation__wiki/39255/customizing-ribbons-and-tool-bars
Hope this helps!
- Jayson P.
