Since using MicroStation Connection Client I have had nothing but problems with mouse inputs particularly mouse movements being interpreted as clicks I have adjusted mouse settings many times over with no effect. I have tried using different mice but the problem reoccurs it is so bad now that productivity has halved. This is particularly noticeable when placing lines. measuring and copying objects
You mention 'MicroStation Connection Client' these are two separate tools, did you mean MicroStation CONNECT Edition and which version ?
Also which operating System / Mouse / Driver version is being used.
Have you tried resetting your Preferences (How to Back Up and Restore User Preferences & (+) Restore MicroStation to Factory defaults - MicroStation Wiki - MicroStation - Bentley Communities)
May be the issue is not with your Mouse, but Graphics related, see this thread and associated Wiki
Carl Myhill
Technical Support Engineer
Bentley Systems
The setting that has been most helpful is to go into my MicroStation Preferences, to the Input section, and change my mouse (Sensitivity?) there to "Slow". It's not your actual mouse settings as much as it is the way MicroStation is interpreting your mouse.
I'm not in MicroStation right now or I could give you the exact name of it...
MaryB
Yes, in the Input section of User Preferences.
Thanks, Bob!
This was one of the first fixes suggested unfortunately no change but thanks for input
