Seems I come across another reference bug in U17. Attached is a sample file, created using the Metrostation workset.
In the model named "sheet", there're 2 references with live nesting turned on.
They are the same reference, just offset for visual effect. There are some clip masks to mask out the middle part of the white shape.
If I change the nesting option for 1 of the references from "live nesting" to "copy attachments", the "clip mask" of the nested references then turned into "clip boundary", effectively the masking is reversed.
Just wondering if a bug has been filed for this? Same behaviour observed when using "Make direct attachment" command.
Best regards,
Tuan Le
u17_Metrostation.dgn
Confirming Bob's comment, this has been reported previously and Bug 654397 has been filed.
Carl Myhill
Technical Support Engineer
Bentley Systems
Thanks for confirming Carl. Just wondering if there's an ETA for this to be fixed?
I noticed you have already logged this as a Service Request, I will arrange for the Bug to be added to this such that you are notified of any further changes and see if we can obtain an ETA.
