When exporting my dgn to a kmz file, everything seems to be exporting on the correct levels etc, except some elements are not maintaining their color. The first image is of the kmz as it appears in google earth, and the second image is of the dgn as it appears in MicroStation V8i. The green lines, along with a few others, in Microstation are appearing as white lines on google earth. Any ideas?
Which version of MicroStation and Google Earth are you using?Is there any change you are using level overrides?
*chance
MaryB
just a wild stab in the dark but make a copy and change all your colours to true colour ie rgb and try that to kmz.. but make sure as mary stated no overrides used...
Lorys
