Why was the simple model properties changed?
Again another production slow down.
I like the idea of the detailed properties if desired, but to change model annotation scale, sheet size , design , sheet and drawing
import a model
create a new model
ugh!
ADD THE OLD V8 COMPACT MENU BACK AND MAKE THE DETAIL PROPERTIES AN OPTION
Hi Kirk,
If you believe the old menu used in older versions is more efficient, please make the request using ideas forum MicroStation Ideas Portal (aha.io)
In older versions the models dialog allowed you to select the model properties and some few options directly from there. see below
while in Connect edition this model properties icon from Models dialog only opens the general Properties dialog with much more options.
if you prefer the old option please go ahead and file the request for this dialog to be back.
