Hello guys,
I am currently using MicroStation connect 10 with windows 11 and I am wondering how I can get the xsl file in order to customize a standards checker report.
The main issue here is that I create a workspace and a worksheet where I have set up a dgnlib file for the standards checker.
So the checker works but when it comes to display the report I do not have the basic report. I have just some lines in a html webpage displaying in a sentence the report.
So before trying to customize the standards checker.xsl file. I need to know how to make MicroStation pointing to that file or place my dgnlib in the right place in order to make the whole thing work.
The thing is that my dgnlib is in this path:
C:\Users\Public\appllications\palette\Data\workspace\workset\dgnlib\
And the xsl file is in a standard location created during the installation of the software
C:\Users\Programmes\Bentley\Microstation\....\Data
Another thing is that do not have the writing rights for this folder so I am stuck.
I have read somewhere that we could define the path of the xsl file via an Ms_standardschecker_stylesheet but I can t find it.
So the issue is more about the right path of those files.
So I hope you guys understand my issue and I am counting on your help.
DAMIEN D'ORAZIO said:I have read somewhere that we could define the path of the xsl file via an Ms_standardschecker_stylesheet but I can t find it
It's in MicroStation Help: Standards Checker Configuration Variables.
Copy the existing standardschecker.Xsl to a location where you have editing rights, then add or modify MS_STANDARDSCHECKER_STYLESHEET to point to your file.
DAMIEN D'ORAZIO said:I have just some lines in a html webpage
There should be a .xml report somewhere.
.xml
Hi Thanks for the reply,
I am close to reach my goal but I still do not have the xml right has you can see below:
Here is what I how I set the paths:
then standardschecker fil:
my dgnlib
the variable settings
I don't know what is wrong for me, it should work as I follow your instructions. May be the dgnlib and the xsl file needs to be in the same folder, I don't know. I am looking for your thoughts ;-). The standardschecker file is joint to this message, but its the original I didn't touch it yet.
Thanks anyway.
standardschecker.xsl
DAMIEN D'ORAZIO said:I am close to reach my goal
MS_STANDARDSCHECKER_OUT
Thanks for your reply,
1/ Here are some of screenshots that will reply to some of your questions. But regarding the report file text box, I'm afraid that I don't get your meaning.
2/ So yes it does create an xml file into the folder expected but the thing is that it is not transformed by the xsl file and shows only raw data for instance what the errors detected and non corrected.
I had the xml output file from the standard checker below.
<?xml version="1.0" encoding="Windows-1252"?> <?xml-stylesheet href="file:///C:/Users/Public/Applications/PALETTE_OUTILS_V1/Data/data_microstation/Carto Enedis/WorkSets/Carto ENEDIS/Standards/Data/standardschecker.xsl" type="text/xsl"?> <StandardsCheckerReport name="V�rificateur de standards de Bentley Systems, Inc." version="Version 10.14.0.109"> <SettingsFile name="C:\Users\Public\Applications\PALETTE_OUTILS_V1\Data\data_microstation\Carto Enedis\WorkSets\Carto ENEDIS\Standards\Dgnlib\NIVEAUX NORMALISES-ENEDISv1.dgnlib" time="2022/08/25 08:35:59" size="96768" format="DGNV8" lastauthor="DDC1DDDN"/> <Settings name="CONTROLE_CARTO_ENEDIS" description=""/> <StandardsCheckerApps> <StandardsCheckerApp name="V�rificateur de niveaux de Bentley Systems, Inc." alias="LevelChecker" version="Version 10.14.0.109" description="V�rifie les propri�t�s des niveaux par rapport aux niveaux standard"> <Libraries> <Library id="1" name="C:\Users\Public\Applications\PALETTE_OUTILS_V1\Data\data_microstation\Carto Enedis\WorkSets\Carto ENEDIS\Standards\Dgnlib\NIVEAUX NORMALISES-ENEDISv1.dgnlib" time="2022/08/25 08:35:59" size="96768" format="DGNV8" lastauthor="DDC1DDDN"> <Standards> <Standard name="PGOC_HABILLAGE_RESEAU" type="Niveau"> <Properties> <Property name="Couleur" value="0"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="0"/> </Properties> </Standard> <Standard name="PGOC_HABILLAGE_PGOC" type="Niveau"> <Properties> <Property name="Couleur" value="0"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="0"/> </Properties> </Standard> <Standard name="PGOC_HTA_ABANDONNE" type="Niveau"> <Properties> <Property name="Couleur" value="0"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="ST_ABAND"/> </Properties> </Standard> <Standard name="PGOC_BT_ABANDONNE" type="Niveau"> <Properties> <Property name="Couleur" value="0"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="ST_ABAND"/> </Properties> </Standard> <Standard name="PGOC_BRCHT_ABANDONNE" type="Niveau"> <Properties> <Property name="Couleur" value="0"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="ST_ABAND"/> </Properties> </Standard> <Standard name="PGOC_TERRE" type="Niveau"> <Properties> <Property name="Couleur" value="6"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="ST_PROT_TERRE"/> </Properties> </Standard> <Standard name="PGOC_BRCHT_DI_CONSTRUIT" type="Niveau"> <Properties> <Property name="Couleur" value="23"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="0"/> </Properties> </Standard> <Standard name="PGOC_POSTE_CONSTRUIT" type="Niveau"> <Properties> <Property name="Couleur" value="9"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="0"/> </Properties> </Standard> <Standard name="PGOC_BRCHT_LR_ABANDONNE" type="Niveau"> <Properties> <Property name="Couleur" value="0"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="ST_ABAND"/> </Properties> </Standard> <Standard name="PGOC_BRCHT_LR_CONSTRUIT" type="Niveau"> <Properties> <Property name="Couleur" value="23"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="0"/> </Properties> </Standard> <Standard name="PGOC_AUTRE_RESEAU" type="Niveau"> <Properties> <Property name="Couleur" value="0"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="0"/> </Properties> </Standard> <Standard name="PGOC_PROTECTION_MECANIQUE" type="Niveau"> <Properties> <Property name="Couleur" value="6"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="0"/> </Properties> </Standard> <Standard name="PGOC_BT_CONSTRUIT" type="Niveau"> <Properties> <Property name="Couleur" value="7"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="0"/> </Properties> </Standard> <Standard name="PGOC_PTRL" type="Niveau"> <Properties> <Property name="Couleur" value="48"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="0"/> </Properties> </Standard> <Standard name="PGOC_BRCHT_CONSTRUIT" type="Niveau"> <Properties> <Property name="Couleur" value="23"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="0"/> </Properties> </Standard> <Standard name="PGOC_HTA_CONSTRUIT" type="Niveau"> <Properties> <Property name="Couleur" value="3"/> <Property name="Epaisseur" value="0"/> <Property name="Style" value="0"/> </Properties> </Standard> </Standards> </Library> </Libraries> </StandardsCheckerApp> <StandardsCheckerApp name="V�rificateur de styles de texte de Bentley Systems, Inc." alias="TextStyleChecker" version="Version 10.14.0.109" description="V�rifie les propri�t�s de style de texte par rapport aux styles de texte standard"> <Libraries> <Library id="1" name="C:\Users\Public\Applications\PALETTE_OUTILS_V1\Data\data_microstation\Carto Enedis\WorkSets\Carto ENEDIS\Standards\Dgnlib\NIVEAUX NORMALISES-ENEDISv1.dgnlib" time="2022/08/25 08:35:59" size="96768" format="DGNV8" lastauthor="DDC1DDDN"> <Standards> <Standard name="Text_BRCHT-BT" type="Style de Texte"> <Properties> <Property name="Police" value="INTL_ENGINEERING"/> <Property name="Largeur" value="0.0280"/> <Property name="Hauteur" value="0.0400"/> <Property name="Angle d'inclinaison" value="0.000000"/> <Property name="Type d'espacement de ligne" value="Automatique"/> <Property name="Interligne" value="1.000000"/> <Property name="Espacement entre caract�res" value="0.0000"/> <Property name="D�calage de soulignement" value="0.0000"/> <Property name="D�calage de surlignement" value="0.0000"/> <Property name="D�calage de ligne en X" value="0.0000"/> <Property name="D�calage de ligne en y" value="0.0000"/> <Property name="Justification" value="Centre centre"/> <Property name="Justification de noeud" value="Centre centre"/> <Property name="Longueur de ligne" value="255"/> <Property name="Direction du texte" value=""/> <Property name="Soulign�" value="0"/> <Property name="Style soulignement" value="0"/> <Property name="Couleur trait de soulignement" value="7"/> <Property name="Style trait de soulignement" value="0"/> <Property name="Epaisseur trait de soulignement" value="0"/> <Property name="Surlign�" value="0"/> <Property name="Style surlignement" value="0"/> <Property name="Couleur trait de surlignement" value="0"/> <Property name="Style trait de surlignement" value="0"/> <Property name="Epaisseur trait de surlignement" value="0"/> <Property name="Arri�re-plan" value="0"/> <Property name="Couleur bordure d'arri�re-plan" value="0"/> <Property name="Style bordure d'arri�re-plan" value="0"/> <Property name="Epaisseur bordure d'arri�re-plan" value="0"/> <Property name="Couleur de remplissage d'arri�re-plan" value="0"/> <Property name="X bordure d'arri�re-plan" value="0.0000"/> <Property name="Y bordure d'arri�re-plan" value="0.0000"/> <Property name="Couleur" value="1"/> <Property name="Couleur de texte" value="23"/> <Property name="Italique" value="0"/> <Property name="Gras" value="0"/> <Property name="Indice sup�rieur" value="0"/> <Property name="Indice inf�rieur" value="0"/> <Property name="Espacement d�fini" value="0"/> <Property name="Fractions" value="1"/> <Property name="Justification compl�te" value="0"/> </Properties> </Standard> <Standard name="Text_HTA" type="Style de Texte"> <Properties> <Property name="Police" value="INTL_ENGINEERING"/> <Property name="Largeur" value="0.0280"/> <Property name="Hauteur" value="0.0400"/> <Property name="Angle d'inclinaison" value="0.000000"/> <Property name="Type d'espacement de ligne" value="Automatique"/> <Property name="Interligne" value="1.000000"/> <Property name="Espacement entre caract�res" value="0.0000"/> <Property name="D�calage de soulignement" value="0.0000"/> <Property name="D�calage de surlignement" value="0.0000"/> <Property name="D�calage de ligne en X" value="0.0000"/> <Property name="D�calage de ligne en y" value="0.0000"/> <Property name="Justification" value="Centre centre"/> <Property name="Justification de noeud" value="Centre centre"/> <Property name="Longueur de ligne" value="255"/> <Property name="Direction du texte" value=""/> <Property name="Soulign�" value="0"/> <Property name="Style soulignement" value="0"/> <Property name="Couleur trait de soulignement" value="0"/> <Property name="Style trait de soulignement" value="0"/> <Property name="Epaisseur trait de soulignement" value="0"/> <Property name="Surlign�" value="0"/> <Property name="Style surlignement" value="0"/> <Property name="Couleur trait de surlignement" value="0"/> <Property name="Style trait de surlignement" value="0"/> <Property name="Epaisseur trait de surlignement" value="0"/> <Property name="Arri�re-plan" value="0"/> <Property name="Couleur bordure d'arri�re-plan" value="0"/> <Property name="Style bordure d'arri�re-plan" value="0"/> <Property name="Epaisseur bordure d'arri�re-plan" value="0"/> <Property name="Couleur de remplissage d'arri�re-plan" value="0"/> <Property name="X bordure d'arri�re-plan" value="0.0000"/> <Property name="Y bordure d'arri�re-plan" value="0.0000"/> <Property name="Couleur" value="1"/> <Property name="Couleur de texte" value="3"/> <Property name="Italique" value="0"/> <Property name="Gras" value="0"/> <Property name="Indice sup�rieur" value="0"/> <Property name="Indice inf�rieur" value="0"/> <Property name="Espacement d�fini" value="0"/> <Property name="Fractions" value="1"/> <Property name="Justification compl�te" value="0"/> </Properties> </Standard> <Standard name="Text_FOURREAU_MALT" type="Style de Texte"> <Properties> <Property name="Police" value="INTL_ENGINEERING"/> <Property name="Largeur" value="0.0280"/> <Property name="Hauteur" value="0.0400"/> <Property name="Angle d'inclinaison" value="0.000000"/> <Property name="Type d'espacement de ligne" value="Automatique"/> <Property name="Interligne" value="1.000000"/> <Property name="Espacement entre caract�res" value="0.0000"/> <Property name="D�calage de soulignement" value="0.0000"/> <Property name="D�calage de surlignement" value="0.0000"/> <Property name="D�calage de ligne en X" value="0.0000"/> <Property name="D�calage de ligne en y" value="0.0000"/> <Property name="Justification" value="Centre centre"/> <Property name="Justification de noeud" value="Centre centre"/> <Property name="Longueur de ligne" value="255"/> <Property name="Direction du texte" value=""/> <Property name="Soulign�" value="0"/> <Property name="Style soulignement" value="0"/> <Property name="Couleur trait de soulignement" value="7"/> <Property name="Style trait de soulignement" value="0"/> <Property name="Epaisseur trait de soulignement" value="0"/> <Property name="Surlign�" value="0"/> <Property name="Style surlignement" value="0"/> <Property name="Couleur trait de surlignement" value="0"/> <Property name="Style trait de surlignement" value="0"/> <Property name="Epaisseur trait de surlignement" value="0"/> <Property name="Arri�re-plan" value="0"/> <Property name="Couleur bordure d'arri�re-plan" value="0"/> <Property name="Style bordure d'arri�re-plan" value="0"/> <Property name="Epaisseur bordure d'arri�re-plan" value="0"/> <Property name="Couleur de remplissage d'arri�re-plan" value="0"/> <Property name="X bordure d'arri�re-plan" value="0.0000"/> <Property name="Y bordure d'arri�re-plan" value="0.0000"/> <Property name="Couleur" value="1"/> <Property name="Couleur de texte" value="6"/> <Property name="Italique" value="0"/> <Property name="Gras" value="0"/> <Property name="Indice sup�rieur" value="0"/> <Property name="Indice inf�rieur" value="0"/> <Property name="Espacement d�fini" value="0"/> <Property name="Fractions" value="1"/> <Property name="Justification compl�te" value="0"/> </Properties> </Standard> <Standard name="Text_PTRL" type="Style de Texte"> <Properties> <Property name="Police" value="INTL_ENGINEERING"/> <Property name="Largeur" value="0.0280"/> <Property name="Hauteur" value="0.0400"/> <Property name="Angle d'inclinaison" value="0.000000"/> <Property name="Type d'espacement de ligne" value="Automatique"/> <Property name="Interligne" value="1.000000"/> <Property name="Espacement entre caract�res" value="0.0000"/> <Property name="D�calage de soulignement" value="0.0000"/> <Property name="D�calage de surlignement" value="0.0000"/> <Property name="D�calage de ligne en X" value="0.0000"/> <Property name="D�calage de ligne en y" value="0.0000"/> <Property name="Justification" value="Centre centre"/> <Property name="Justification de noeud" value="Centre centre"/> <Property name="Longueur de ligne" value="255"/> <Property name="Direction du texte" value=""/> <Property name="Soulign�" value="0"/> <Property name="Style soulignement" value="0"/> <Property name="Couleur trait de soulignement" value="7"/> <Property name="Style trait de soulignement" value="0"/> <Property name="Epaisseur trait de soulignement" value="0"/> <Property name="Surlign�" value="0"/> <Property name="Style surlignement" value="0"/> <Property name="Couleur trait de surlignement" value="0"/> <Property name="Style trait de surlignement" value="0"/> <Property name="Epaisseur trait de surlignement" value="0"/> <Property name="Arri�re-plan" value="0"/> <Property name="Couleur bordure d'arri�re-plan" value="0"/> <Property name="Style bordure d'arri�re-plan" value="0"/> <Property name="Epaisseur bordure d'arri�re-plan" value="0"/> <Property name="Couleur de remplissage d'arri�re-plan" value="0"/> <Property name="X bordure d'arri�re-plan" value="0.0000"/> <Property name="Y bordure d'arri�re-plan" value="0.0000"/> <Property name="Couleur" value="1"/> <Property name="Couleur de texte" value="-1"/> <Property name="Italique" value="0"/> <Property name="Gras" value="0"/> <Property name="Indice sup�rieur" value="0"/> <Property name="Indice inf�rieur" value="0"/> <Property name="Espacement d�fini" value="0"/> <Property name="Fractions" value="1"/> <Property name="Justification compl�te" value="0"/> </Properties> </Standard> <Standard name="Text_BT" type="Style de Texte"> <Properties> <Property name="Police" value="INTL_ENGINEERING"/> <Property name="Largeur" value="0.0280"/> <Property name="Hauteur" value="0.0400"/> <Property name="Angle d'inclinaison" value="0.000000"/> <Property name="Type d'espacement de ligne" value="Automatique"/> <Property name="Interligne" value="1.000000"/> <Property name="Espacement entre caract�res" value="0.0000"/> <Property name="D�calage de soulignement" value="0.0000"/> <Property name="D�calage de surlignement" value="0.0000"/> <Property name="D�calage de ligne en X" value="0.0000"/> <Property name="D�calage de ligne en y" value="0.0000"/> <Property name="Justification" value="Centre centre"/> <Property name="Justification de noeud" value="Centre centre"/> <Property name="Longueur de ligne" value="0"/> <Property name="Direction du texte" value=""/> <Property name="Soulign�" value="0"/> <Property name="Style soulignement" value="0"/> <Property name="Couleur trait de soulignement" value="0"/> <Property name="Style trait de soulignement" value="0"/> <Property name="Epaisseur trait de soulignement" value="0"/> <Property name="Surlign�" value="0"/> <Property name="Style surlignement" value="0"/> <Property name="Couleur trait de surlignement" value="0"/> <Property name="Style trait de surlignement" value="0"/> <Property name="Epaisseur trait de surlignement" value="0"/> <Property name="Arri�re-plan" value="0"/> <Property name="Couleur bordure d'arri�re-plan" value="0"/> <Property name="Style bordure d'arri�re-plan" value="0"/> <Property name="Epaisseur bordure d'arri�re-plan" value="0"/> <Property name="Couleur de remplissage d'arri�re-plan" value="0"/> <Property name="X bordure d'arri�re-plan" value="0.0000"/> <Property name="Y bordure d'arri�re-plan" value="0.0000"/> <Property name="Couleur" value="1"/> <Property name="Couleur de texte" value="7"/> <Property name="Italique" value="0"/> <Property name="Gras" value="0"/> <Property name="Indice sup�rieur" value="0"/> <Property name="Indice inf�rieur" value="0"/> <Property name="Espacement d�fini" value="0"/> <Property name="Fractions" value="1"/> <Property name="Justification compl�te" value="0"/> </Properties> </Standard> <Standard name="Ligne de corps" type="Style de Texte"> <Properties> <Property name="Police" value="Calibri"/> <Property name="Largeur" value="5.0000"/> <Property name="Hauteur" value="5.0000"/> <Property name="Angle d'inclinaison" value="0.000000"/> <Property name="Type d'espacement de ligne" value="Exact"/> <Property name="Interligne" value="0.000000"/> <Property name="Espacement entre caract�res" value="0.0000"/> <Property name="D�calage de soulignement" value="0.0000"/> <Property name="D�calage de surlignement" value="0.0000"/> <Property name="D�calage de ligne en X" value="0.0000"/> <Property name="D�calage de ligne en y" value="0.0000"/> <Property name="Justification" value="En haut � gauche"/> <Property name="Justification de noeud" value="En haut � gauche"/> <Property name="Longueur de ligne" value="0"/> <Property name="Direction du texte" value=""/> <Property name="Soulign�" value="0"/> <Property name="Style soulignement" value="0"/> <Property name="Couleur trait de soulignement" value="0"/> <Property name="Style trait de soulignement" value="0"/> <Property name="Epaisseur trait de soulignement" value="0"/> <Property name="Surlign�" value="0"/> <Property name="Style surlignement" value="0"/> <Property name="Couleur trait de surlignement" value="0"/> <Property name="Style trait de surlignement" value="0"/> <Property name="Epaisseur trait de surlignement" value="0"/> <Property name="Arri�re-plan" value="0"/> <Property name="Couleur bordure d'arri�re-plan" value="0"/> <Property name="Style bordure d'arri�re-plan" value="0"/> <Property name="Epaisseur bordure d'arri�re-plan" value="0"/> <Property name="Couleur de remplissage d'arri�re-plan" value="0"/> <Property name="X bordure d'arri�re-plan" value="0.0000"/> <Property name="Y bordure d'arri�re-plan" value="0.0000"/> <Property name="Couleur" value="1"/> <Property name="Couleur de texte" value="516"/> <Property name="Italique" value="0"/> <Property name="Gras" value="0"/> <Property name="Indice sup�rieur" value="0"/> <Property name="Indice inf�rieur" value="0"/> <Property name="Espacement d�fini" value="0"/> <Property name="Fractions" value="0"/> <Property name="Justification compl�te" value="0"/> </Properties> </Standard> <Standard name="Ligne de corps-1" type="Style de Texte"> <Properties> <Property name="Police" value="Calibri"/> <Property name="Largeur" value="0.0002"/> <Property name="Hauteur" value="0.0002"/> <Property name="Angle d'inclinaison" value="0.000000"/> <Property name="Type d'espacement de ligne" value="Exact"/> <Property name="Interligne" value="0.000000"/> <Property name="Espacement entre caract�res" value="0.0000"/> <Property name="D�calage de soulignement" value="0.0000"/> <Property name="D�calage de surlignement" value="0.0000"/> <Property name="D�calage de ligne en X" value="0.0000"/> <Property name="D�calage de ligne en y" value="0.0000"/> <Property name="Justification" value="En haut � gauche"/> <Property name="Justification de noeud" value="En haut � gauche"/> <Property name="Longueur de ligne" value="0"/> <Property name="Direction du texte" value=""/> <Property name="Soulign�" value="0"/> <Property name="Style soulignement" value="0"/> <Property name="Couleur trait de soulignement" value="0"/> <Property name="Style trait de soulignement" value="0"/> <Property name="Epaisseur trait de soulignement" value="0"/> <Property name="Surlign�" value="0"/> <Property name="Style surlignement" value="0"/> <Property name="Couleur trait de surlignement" value="0"/> <Property name="Style trait de surlignement" value="0"/> <Property name="Epaisseur trait de surlignement" value="0"/> <Property name="Arri�re-plan" value="0"/> <Property name="Couleur bordure d'arri�re-plan" value="0"/> <Property name="Style bordure d'arri�re-plan" value="0"/> <Property name="Epaisseur bordure d'arri�re-plan" value="0"/> <Property name="Couleur de remplissage d'arri�re-plan" value="0"/> <Property name="X bordure d'arri�re-plan" value="0.0000"/> <Property name="Y bordure d'arri�re-plan" value="0.0000"/> <Property name="Couleur" value="1"/> <Property name="Couleur de texte" value="516"/> <Property name="Italique" value="0"/> <Property name="Gras" value="0"/> <Property name="Indice sup�rieur" value="0"/> <Property name="Indice inf�rieur" value="0"/> <Property name="Espacement d�fini" value="0"/> <Property name="Fractions" value="0"/> <Property name="Justification compl�te" value="0"/> </Properties> </Standard> <Standard name="Ligne de corps-2" type="Style de Texte"> <Properties> <Property name="Police" value="Calibri"/> <Property name="Largeur" value="0.0015"/> <Property name="Hauteur" value="0.0015"/> <Property name="Angle d'inclinaison" value="0.000000"/> <Property name="Type d'espacement de ligne" value="Exact"/> <Property name="Interligne" value="0.000000"/> <Property name="Espacement entre caract�res" value="0.0000"/> <Property name="D�calage de soulignement" value="0.0000"/> <Property name="D�calage de surlignement" value="0.0000"/> <Property name="D�calage de ligne en X" value="0.0000"/> <Property name="D�calage de ligne en y" value="0.0000"/> <Property name="Justification" value="En haut � gauche"/> <Property name="Justification de noeud" value="En haut � gauche"/> <Property name="Longueur de ligne" value="0"/> <Property name="Direction du texte" value=""/> <Property name="Soulign�" value="0"/> <Property name="Style soulignement" value="0"/> <Property name="Couleur trait de soulignement" value="0"/> <Property name="Style trait de soulignement" value="0"/> <Property name="Epaisseur trait de soulignement" value="0"/> <Property name="Surlign�" value="0"/> <Property name="Style surlignement" value="0"/> <Property name="Couleur trait de surlignement" value="0"/> <Property name="Style trait de surlignement" value="0"/> <Property name="Epaisseur trait de surlignement" value="0"/> <Property name="Arri�re-plan" value="0"/> <Property name="Couleur bordure d'arri�re-plan" value="0"/> <Property name="Style bordure d'arri�re-plan" value="0"/> <Property name="Epaisseur bordure d'arri�re-plan" value="0"/> <Property name="Couleur de remplissage d'arri�re-plan" value="0"/> <Property name="X bordure d'arri�re-plan" value="0.0000"/> <Property name="Y bordure d'arri�re-plan" value="0.0000"/> <Property name="Couleur" value="1"/> <Property name="Couleur de texte" value="516"/> <Property name="Italique" value="0"/> <Property name="Gras" value="0"/> <Property name="Indice sup�rieur" value="0"/> <Property name="Indice inf�rieur" value="0"/> <Property name="Espacement d�fini" value="0"/> <Property name="Fractions" value="0"/> <Property name="Justification compl�te" value="0"/> </Properties> </Standard> <Standard name="Ligne de corps-3" type="Style de Texte"> <Properties> <Property name="Police" value="Calibri"/> <Property name="Largeur" value="0.0100"/> <Property name="Hauteur" value="0.0100"/> <Property name="Angle d'inclinaison" value="0.000000"/> <Property name="Type d'espacement de ligne" value="Exact"/> <Property name="Interligne" value="0.000000"/> <Property name="Espacement entre caract�res" value="0.0000"/> <Property name="D�calage de soulignement" value="0.0000"/> <Property name="D�calage de surlignement" value="0.0000"/> <Property name="D�calage de ligne en X" value="0.0000"/> <Property name="D�calage de ligne en y" value="0.0000"/> <Property name="Justification" value="Centre centre"/> <Property name="Justification de noeud" value="Centre centre"/> <Property name="Longueur de ligne" value="0"/> <Property name="Direction du texte" value=""/> <Property name="Soulign�" value="0"/> <Property name="Style soulignement" value="0"/> <Property name="Couleur trait de soulignement" value="0"/> <Property name="Style trait de soulignement" value="0"/> <Property name="Epaisseur trait de soulignement" value="0"/> <Property name="Surlign�" value="0"/> <Property name="Style surlignement" value="0"/> <Property name="Couleur trait de surlignement" value="0"/> <Property name="Style trait de surlignement" value="0"/> <Property name="Epaisseur trait de surlignement" value="0"/> <Property name="Arri�re-plan" value="0"/> <Property name="Couleur bordure d'arri�re-plan" value="0"/> <Property name="Style bordure d'arri�re-plan" value="0"/> <Property name="Epaisseur bordure d'arri�re-plan" value="0"/> <Property name="Couleur de remplissage d'arri�re-plan" value="0"/> <Property name="X bordure d'arri�re-plan" value="0.0000"/> <Property name="Y bordure d'arri�re-plan" value="0.0000"/> <Property name="Couleur" value="1"/> <Property name="Couleur de texte" value="516"/> <Property name="Italique" value="0"/> <Property name="Gras" value="0"/> <Property name="Indice sup�rieur" value="0"/> <Property name="Indice inf�rieur" value="0"/> <Property name="Espacement d�fini" value="0"/> <Property name="Fractions" value="0"/> <Property name="Justification compl�te" value="0"/> </Properties> </Standard> </Standards> </Library> </Libraries> </StandardsCheckerApp> <StandardsCheckerApp name="V�rificateur de gabarits d'�l�ment de Bentley Systems, Inc." alias="TemplateChecker" version="Version 10.14.0.109" description="Compare les propri�t�s des gabarits d'�l�ment avec celles des mod�les d'�l�ment standard ainsi que les �l�ments du fichier de conception actif avec les gabarits d'�l�ment inclus dans ce fichier."> <Libraries> <Library id="1" name="C:\Users\Public\Applications\PALETTE_OUTILS_V1\Data\data_microstation\Carto Enedis\WorkSets\Carto ENEDIS\Standards\Dgnlib\NIVEAUX NORMALISES-ENEDISv1.dgnlib" time="2022/08/25 08:35:59" size="96768" format="DGNV8" lastauthor="DDC1DDDN"> <Standards/> </Library> </Libraries> </StandardsCheckerApp> </StandardsCheckerApps> <DgnFiles> <File id="1" CheckTime="2022/08/25 13:05:45" name="C:\Temp\presentation palette\FICHIER EXEMPLE-SIGMA.dgn" time="2022/08/12 13:32:08" size="205824" format="DGNV8" lastauthor="DDC1DDDN"> <Models> <Model name="Model" id="0" description=""/> </Models> </File> </DgnFiles> <Problems> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="1" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>CARROYAGE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="1" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>CARTOUCHE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="1" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>RESEAUX-PTT</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="1" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>PTS-TOPO</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="1" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>RESEAUX-ELECTRICITE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>RESEAUX-ECLAIRAGE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>LIMITE-NATURE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>PTS-TOPO-ALTIMETRIE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>PTS-TOPO-CODE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>PTS-TOPO-NUMERO</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>NOM-RUE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>RESEAUX-ECLAIRAGE-SYMB</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>RESEAUX-ECLAIRAGE-TEXTE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="1" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>RESEAUX-PTT-TEXTE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>RESEAUX-ECLAIRAGE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>LIMITE-NATURE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>PTS-TOPO-ALTIMETRIE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>PTS-TOPO-CODE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>PTS-TOPO-NUMERO</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>NOM-RUE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>RESEAUX-ECLAIRAGE-SYMB</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>RESEAUX-ECLAIRAGE-TEXTE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>RESEAUX-PTT-SYMB</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>RESEAUX-ELECTRICITE-SYMB</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>RESEAUX-ELECTRICITE-BT-SYMB</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>LEGENDE</Standard> </Problem> <Problem fileId="1" modelId="0" appId="LevelChecker" ignored="0" fixed="0" type="Niveau"> <Description>Le nom du niveau ne correspond � aucun niveau standard</Description> <Standard>0</Standard> </Problem> <Problem fileId="1" modelId="0" appId="TextStyleChecker" ignored="0" fixed="0" type="Style de Texte"> <Description>Le nom du style de texte ne concorde avec aucun style de texte standard.</Description> <Standard>Standard</Standard> </Problem> <Problem fileId="1" modelId="0" appId="TextStyleChecker" ignored="0" fixed="0" type="Style de Texte"> <Description>Le nom du style de texte ne concorde avec aucun style de texte standard.</Description> <Standard>BAT-DES</Standard> </Problem> <Problem fileId="1" modelId="0" appId="TextStyleChecker" ignored="0" fixed="0" type="Style de Texte"> <Description>Le nom du style de texte ne concorde avec aucun style de texte standard.</Description> <Standard>POI-NUM</Standard> </Problem> <Problem fileId="1" modelId="0" appId="TextStyleChecker" ignored="0" fixed="0" type="Style de Texte"> <Description>Le nom du style de texte ne concorde avec aucun style de texte standard.</Description> <Standard>POI-ALT</Standard> </Problem> <Problem fileId="1" modelId="0" appId="TextStyleChecker" ignored="0" fixed="0" type="Style de Texte"> <Description>Le nom du style de texte ne concorde avec aucun style de texte standard.</Description> <Standard>STA-DIV</Standard> </Problem> <Problem fileId="1" modelId="0" appId="TextStyleChecker" ignored="0" fixed="0" type="Style de Texte"> <Description>Le nom du style de texte ne concorde avec aucun style de texte standard.</Description> <Standard>ROMANS</Standard> </Problem> </Problems> <LastFileChecked name="C:\Temp\presentation palette\FICHIER EXEMPLE-SIGMA.dgn" time="2022/08/25 13:06:12" size="205824" format="DGNV8" lastauthor="DDC1DDDN"/> </StandardsCheckerReport>
DAMIEN D'ORAZIO said:yes it does create an xml file into the folder expected but the thing is that it is not transformed by the xsl file
What do you use to view that XML file? You need an app or browser than can read and transform XML using XSL.
For example, XMLSpy or Notepad++.
