How can I get the error "System.OutOfMemoryException" when my system has "Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz 3.79 GHz" and 64 GB of RAM?
Is it because the program is poorly designed in such a way that it doesn't allow it to use my systems full power or even a fraction of it?
Parents Reply
  • Does not sound to me like your files are over stressing the computer. Even with the 32-bit Microstation, you should not get that error, it's supposed to slide over and use the hard drive when it needs it.
    Connect has a multitude of bugs but the 64-bit bit seems a necessary improvement. Once you get the configuration "cleaned up", I find it's noticeably quicker than v8i.
