I've just got a couple of questions regarding display rule patterning.
1 - Can it be used for forward view? It works well for cut view, and can be used for back view.
2 - Is there any way to set patterning cell horizontal and vertical distance?
Best regards,
Tuan Le
I'm not sure I understand what you're wanting as an end product. When you perform a Section Callout it would need to cut the element(s) to produce output with this hatch to display like this. Can you explain why you're wanting to produce this cross hatch on the output?
An example would be a plan view where there are multiple elements at different elevation, I would like to have hatching applied to elements that pass the display rules. And that would need to be happening via the "forward" plane, because "cut" plane isn't versatile enough.
To clarify:
You want the patterning ability of a section cut to apply to a view clip?You don't want to place a section, you want your view to automatically pattern items shown?
MaryB
that'll work as well, yes Mary.
Right, found a work around for both issue, hatching/patterning can be achieved by using Geometry Map instead.
