Change View Rotation is an important tool. Re-introduced sometime for CE but not fully integrated. It performs like a macro that does not get updates about what the View is doing. Unhelpfully, the View Prev / Next buffer also does not seem to register changes made by the CVR tool.
View changes generated by the RV=,, command also do not register with View Prev / Next which is a regression?
Well, that's just wrong...
MaryB
What version are you experiencing this issue. I am not seeing an issue with View Previous or View Next not working
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
OBD 9.2 (Mstn 16.3)
Your issue could be specific to OBD. Your post would be better in a forum for that product. I don't use OBD so I am not sure if there is a specific forum for OBD or if that would be in the Road & Site Design forum.
I've noticed that most of the time View Previous doesn't work at all in OpenRoads for me. I'm on the latest CE 2022 Release 1. It just says "No previous viewing operations" no matter what I do.
