Is it possible to turn off markers in referenced files? I use files with many references, which have their own markers. I want them to be turned off, as I don't need them at the moment.
Grzegorz
Presentation/ View Flags? Not at a computer so cant check.
These are markers from attached other file. I want them to be turned off, but at the same time I want to see markers in the file where I'm currently working
I don’t use markers as I find them a visual nuisance so I’m not familiar whether they can be assigned to a level, but I suspect they cannot. The online help shows the Markers are an attribute NOT present within the view flags. As such it seems like they are either all on or off, but I cannot be sure.
docs.bentley.com/.../SetReferencePresentation.html
Hello Grzegorz,
I have had similar question quite a while ago. The answer is twofold:
As long as the reference presentation is set to "From parent", the markers in the reference file(s) will follow the View Flags of the parent view.
2. If you want to have only the markers visible for the active file, and turn off those for the references, I'm afraid that is not possible. It is something I have been looking for as well some time ago, I believe an Enhancement was filed for it. But I can't find the number.
Johan De Cock said:2. If you want to have only the markers visible for the active file, and turn off those for the references, I'm afraid that is not possible. It is something I have been looking for as well some time ago, I believe an Enhancement was filed for it. But I can't find the number.
I created a new MS Idea: View flag for "markers" in reference | MicroStation Ideas Portal (aha.io). In case you are interested, feel free to vote.
