How to turn off markers only in referenced files?
Is it possible to turn off markers in referenced files? I use files with many references, which have their own markers. I want them to be turned off, as I don't need them at the moment.
Grzegorz
  • Hi Johan,
    thank You, I gave my vote to your MS Idea.
  • I posted these before for other view attribute changes.....
    -----------------------------------------------snip--------------
    But here are a few I just tested the part that precedes the true or false is the view attribute feature only trial and error worked for me to work out if its two words or a single word.. but true or false gives on or off.. these work great in batch process .. but remember people can switch things back on or off in the View attributes tool ( only tested in V8i SS10)
    MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 ClipVolume False
    MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 ClipVolume True
    MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Fill True
    MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Fill False
    MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 ACStriad False
    ---------------------------- snip ------------------------------------
    you'll have to do trial and  error for the word for MARKERS and  ends in FALSE to turn off..
    Then you can  put the keyin onto a batch process script it ends with FILEDESIGN so it saves the setting and run it with the batch processor utility  over all the files you want it to fix. IMHO markers  are more trouble than they are  worth. So I have it  set to   off in my all my seed files and for all my  fellow users, perhaps you should do the same to prevent this happening again.
    I hope this helps work around your  problems...
    Lorys
    click link to PM me
  • Then you can  put the keyin onto a batch process script it ends with FILEDESIGN so it saves the setting and run it with the batch processor utility  over all the files you want it to fix
    Hi Lorys,
    If I understand correctly (I'm not too familiar with batch processor), what you propose is to fix a number of files. In all of these files the script would turn off the view flag for markers, right?
    How will that help for the reference files?
    The situation we are looking for is that the markers remain visible for the ACTIVE design file but be turned off for the references.
  • How will that help for the reference files?
    It doesn't, and I'm not sure why anyone would even think of using those key-ins in a batch script either, especially when a more palatable syntax is available
    set markers off; selview all
  • I didnt  know about  the " set markers off"   keyin ... thanks barry  I'll add it to my collection...
    So moving  on use barry's script in  a batch processor script and apply it by adding all your ref  files to the batch
    but if your like most of use we either have refs in a custom folder or use a naming convention to see xrefs
    Lorys
    click link to PM me
