I am using Microstation V8i SELECTseries 10
Version 08.11.09.919
When I load Civtools the Message Center will say "Civtools loaded" But then I am unable to click on anything else, I eventually have to task manager > end task on microstation to be able to restart.
The only fix I have tried is I redownloaded Civtools but that did not work.
This is happening to other people in my office as well.
Do you know where to find a download link for the prerequisite pack. We are having this same issue however given v8i support has been discontinued I am unable to find the pack for download.
Hi Seth, Unfortunately, the prerequisite pack is no longer available for download from the Software Downloads portal as v8i is no longer supported by Bentley.You might try repairing your MicroStation installation via the Windows Apps & Features section while connected to a stable internet connection:
Another thing to try would be to uninstall and then reinstall MicroStation via deployment image. I believe that a properly configured deployment image will include the prereq pack and will not need an internet connection.A Deployment Guide can be found in the Readme documentation. For v8i SS10, it will be located here:C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\readme_MicroStation.chmHere is a snippet from the Readme FAQ:
Question:
Do I need to install the Prerequisites for Bentley Desktop Applications manually before I install MicroStation V8i (SELECTseries 10)?
Answer:
You have the option of installing the Prerequisites for Bentley Desktop Applications manually prior to installing MicroStation V8i (SELECTseries 10) or you can allow the MicroStation V8i (SELECTseries 10) installer to download and install them during the MicroStation V8i (SELECTseries 10) installation. You can also include the Prerequisites for Bentley Desktop Applications in the deployment image. For more information on creating a deployment image, see the Deployment Guide.Hope this helps!-Jayson P.
Hi Levi. Did you get to resolve the issue? We're also experiencing this now. I don't think Civtools is ready for MicroStation CONNECT Edition. Is it? Appreciate your feedback! Thanks!
Janice Mendoza said:I don't think Civtools is ready for MicroStation CONNECT Edition.
Janice,
this discussion was regarding the operation of Civtools in MicroStation V8i SS10 (08.11.09.919) so is not related to MicroStation CONNECT Edition.
The CivTools application was not ported to MicroStation CONNECT Edition but a number of the tools have been included. The following MicroStation Communities Blog may be of assistance in understanding the new tools produced to replace those from the old CivTools application.
communities.bentley.com/.../connect-edition-adoption-blogs-toc
Hi Andrew! Thanks for the prompt response. I asked about MS CONNECT Edition because if we're planning to upgrade to it then we would like to know if Civtools is updated for this version or there are alternatives. Will check the link you sent for sure!
However, we are still indeed using MS V8i SS10 (08.11.09.919) and since last week users are reporting freezing MS when loading Civtools. I was wondering if this got resolved?
Thanks again.
